Electrically Insulated Rolling Bearings
The SQ77 Series of rolling bearings feature built-in electrical insulation for protection against current discharge and the resulting electrical corrosion. Three versions are available: the SQ77 with an oxide ceramic insulation layer on the outer ring; the SQ77E with an insulation layer on the inner ring; and the SQ77B hybrid bearings, which feature ceramic rolling elements with theoretically infinite insulation resistance.
The SQ77 and SQ77E ceramic insulation is applied through plasma-spraying and has a 1,000 Vac/Vdc dielectric strength. The bearings with outer ring insulation are available as cylindrical roller bearings or deep-groove ball bearings in various designs, dimension series and radial clearance classes.
NKE Austria GmbH, 20 Barney Rd., Box 5255, Clifton Park, NY 12065, (518) 371-5759, www.nke.at
