SQ77 Series rolling bearings feature built-in electrical insulation for protection against current discharge and electrical corrosion.
Features & benefits
  • Three versions: SQ77 has an oxide ceramic insulation layer on the outer ring; SQ77E has an insulation layer on the inner ring; SQ77B hybrid bearings feature ceramic rolling elements with theoretically infinite insulation resistance
  • SQ77 and SQ77E ceramic insulation is applied through plasma spraying; 1,000 Vac/Vdc dielectric strength
  • Outer ring insulation available as cylindrical roller bearings or deep-groove ball bearings in various designs, dimensions, clearance classes
NKE Austria GmbH
(518) 371-5759
nke.at/en
