Din-Rail Signal Conditioners
Aug. 18, 2005
The DRF series of 35-mm DIN-rail signal conditioners accept a broad range of input signals, such as ac and dc V and I, frequency, thermocouple and RTD temperature, and process transducers.
In return they provide standard process outputs of either 4-to-20 mA or 0-to-10 Vdc determined by an internal jumper. Connections are made via plug-in screw terminal connectors. Input and output connections are on opposite sides of the module. Span and offset potentiometers are accessible through a front door on the housing. Input, output, and power circuits incorporate 3.5-kV galvanic isolation.
Omega Engineering Inc., 1 Omega Dr., Stamford, CT 06907, (800) 848-4286, omega.com
Strategizing for sustainable success in material handling and packaging
Download our visual factory brochure to explore how, together, we can fully optimize your industrial operations for ongoing success in material handling and packaging. As your...
Fueling the Future of Commercial EV Charging Infrastructure
Miguel Gudino, an Associate Application Engineer at RS, addresses various EV charging challenges and opportunities, ranging from charging station design strategies to the advanced...
