DIN-Rail-Mount Outlet Boxes
Nov. 18, 2010
The CPO Series DIN-rail mount outlet boxes for control cabinets feature a UL-498 receptacle for common tools including laptops and testing equipment
The CPO Series DIN-rail mount outlet boxes for control cabinets feature a UL-498 receptacle for common tools including laptops and testing equipment.
The unit’s PVC housing, with an ABS plastic cover, measures just 60 × 109 mm. A top-mount ground pin prevents loose metal objects (e.g., conductor strands) from shorting hot and neutral pins together. For varying terminations, the box offers either color-coded Cage Clamp spring-pressure termination or MCS pluggable connectors.
The Series consists of 26 variants including: duplex, GFCI, isolated ground, switch models, and PCB-mount outlets.
Wago Corp.
N120 W19129 Freistadt Rd.
Box 1015
Germantown, WI 53022
(800) 346-7245
www.wago.com
© 2010 Penton Media, Inc.
