are compatible with any 35-mm DIN rail and mount to either standard steel high profile or heavy-duty steel DIN rails. The reactors have three lines in and three lines out for cleaner cable layouts and improved cabinet organization. Applying the reactors to the line side of a VFD drive improves overall drive performance. Additional circuit inductance reduces ac-voltage waveform line notching, dc bus overvoltage trips, inverter overvoltage, poor total power factor, and cross talk.
Trans-Coil Inc.
7878 86th St.
Milwaukee, WI 53224
(800) 824-8282
transcoil.com
