Differential-Pressure Transmitters
May 10, 2007
Differential-pressure (DP) transmitters are designed for applications having high line pressures.
The transmitters come in piston and diaphragm-sensor models with ratings of 1,500 to 5,000-psig line pressures. DP ranges are 0-5 to 0-1,000 psid for the piston version and 0-5 to 0-300 psid for the diaphragm model. A Hall-effect sensor transforms DP measurements into an electrical output. The transmitters provide voltage, current, frequency, or RS-232 output. Users select the desired output and a built-in temperaturecompensation makes sure transmitter output doesn't drift. The units can be installed as three or four-wire connections. Optional dials for local readout are available.
Orange Research Inc., 140 Cascade Blvd., Milford, CT 06460, (800) 989-5657, orangeresearch.com
Strategizing for sustainable success in material handling and packaging
Download our visual factory brochure to explore how, together, we can fully optimize your industrial operations for ongoing success in material handling and packaging. As your...
Fueling the Future of Commercial EV Charging Infrastructure
Miguel Gudino, an Associate Application Engineer at RS, addresses various EV charging challenges and opportunities, ranging from charging station design strategies to the advanced...
