Series EK600 large-bore magnetic encoders offer accurate speed and position sensing while withstanding oil, dirt, and temperatures to 100°C.
FEATURES & BENEFITS
- High resolution feedback up to 3,000 cycles/rev from rotating shafts up to 10 in. in diameter
- More than 100 combinations of resolution, wheel OD, and operating air gap available
ADMOTEC INC.
Lebanon, N.H.
(603) 448-7000
www.admotec.com
Circle 109
Inductive proximity sensors
A family of inductive proximity sensors can tolerate harsh outdoor conditions and extreme temperature fluctuations.
FEATURES & BENEFITS
- Stainless-steel housings; IP69K rating
- Operating temperature range of -40 to 185°F
- Ignore radiated electrical interference levels of 100 V/m according to ISO 7637-2 severity level IV
- 12, 18, and 30-mm diameters; flush and non-flush mountable
- 24-Vdc units available hardwired or with quick connectors
IFM EFECTOR INC.
Exton, Pa.
(800) 441-8246
www.ifmefector.com
Circle 110
Washdown coating for speed reducers
Stainless Bost-Kleen (SBK) washdown protection for speed reducers prevents wear and cracking caused by caustic chemicals and high-pressure washdowns.
FEATURES & BENEFITS
- Prevents rust and reduces possibility of bacteria growth
- Uses a Bisphenol-F type epoxy for high chemical, pressure, and thermal resistance
- Available on all of company's speed reducers
BOSTON GEAR
Quincy, Mass.
(888) 999-9860
www.bostongear.com
Circle 110
Sealed linear encoders
Redesigned LC 400 absolute sealed linear encoders incorporate a single-field scanning technology that uses a large single scanning window to increase contamination resistance.
FEATURES & BENEFITS
- Constant signal quality over entire measuring length
- Resolution to 10 nm
- Maximum travel speed to 180 m/min
HEIDENHAIN CORP.
Schaumburg, Ill.
(847) 490-1191
www.heidenhain.com
Circle 112
