Design by Objective: EFFICIENCY
April 1, 2005
Gear drives Drive One high-torque drives offer superior efficiency and performance for high torque, low speed applications. FEATURES & BENEFITS Output
Gear drives
FEATURES & BENEFITS
  • Output torque to 4 million lb-in. (450,000 Nm)
  • Ratios from 145:1 to more than 10 million:1
  • Six sizes in parallel or right-angle configurations
  • Base mounted/coupling connected, shaft mounted/flange connected, or shaft mounted/hollow shaft connected
FALK CORP.
Milwaukee, Wis.
(414) 937-4686
www.falkcorp.com
Circle 183
Servo planetary gearboxes
With a 96% efficiency rate, these high-precision servo planetary gearboxes attach directly to servomotors and provide exceptional torque and stiffness in a small envelope.
FEATURES & BENEFITS
  • High torque (up to 17,701 lb-in.)
  • Low backlash (less than 1 arc/min)
  • Low noise (less than 56 dB)
  • 20,000 hour service life
  • IP65 gearbox protection
TELCO INTERCONTINENTAL CORP.
Houston, Texas
(281) 855-2218
www.telcointercon.com
Circle 185
Geared motors
Three-phase BS Series worm geared motors come as a two-stage design for improved efficiency.
FEATURES & BENEFITS
  • 0.05 to 7.5 hp, 0.2 to 300 rpm, and 220 to 8.850 lbf-in.
  • Single or double output shaft, foot or flange mount, also mounts on keyed hollow shaft or torque arm with shrink disk
  • Insulated enameled copper wire stator windings and aluminum die cast cage rotor and gear wheels
  • IP65 protected (IP66 optional)
DANFOSS BAUER
Somerset, N.J.
(732) 469-8770
www.namc.danfoss.com
Circle 184
High-speed ballscrews
BSS Series ballscrews operate at higher speeds than conventional ballscrews, improving productivity and efficiency.
FEATURES & BENEFITS
  • Linear speeds to 240 m/min
  • Low noise and vibration (6 dB reduction)
  • Compact, lightweight design reduces maximum nut diameter by 30%
NSK PRECISION AMERICA INC.
Addison, Ill.
(630) 620-8500
www.nskprecision.com
Circle 186
Variable frequency drives
F700 variable frequency drives control motors from 1 to 800 hp while boosting motor efficiency and maximizing energy savings.
FEATURES & BENEFITS
  • 200 or 400 V
  • Controls up to four motors
  • Improves motor efficiency by 12%
  • Calculates and displays energy savings in dollars or kW/h
MITSUBISHI ELECTRIC AUTOMATION INC.
Vernon Hills, Ill.
(847) 478-2417
www.meau.com
Circle 187
RS Expert Advice Podcast, Episode 17: Energy Storage Systems
In this episode of the RS Expert Advice Podcast, Joel Boone and Olivia Koicuba of Phoenix Contact introduce energy storage systems, applications, and components, including various...
