The ISO/VDMA cylinder line, cushions can be adjusted to reduce cycle time, noise, and vibration, as well as increase air life. Direction of travel is the same throughout the cushioning sequence and velocity is exactly zero when it reaches the end of its travel. Sequence steps include measuring piston velocity in both directions, adjusting speed to conform to a maximum for a given pressure and cylinder load, and then adjusting the cushions.
Bosch Rexroth Corp.,
1953 Mercer Rd., Lexington, KY 40511,
(859) 854-8031,
www.boschrexroth-us.com
