The 309 Series WOB-L DC pump and compressor is manufactured with corrosion-resistant materials on the inside and a corrosion-resistant treatment on external components. The pump features oilless operation, die-cast aluminum components, steel mounting brackets and isolators, all-wetted-aluminum parts, a stainless-steel inlet valve, and a thermally protected motor. The pump provides up to 26.75-in. HG and 160 psi of maximum intermittent pressure.
Thomas Div., a Gardner Denver Co., 1419 Illinois Ave., Sheboygan, WI 53081, (920) 457-4891, www.gd-thomas.com
