Corrosion-Resistant Cylinders
The CDN Series of corrosion-resistant cylinders is for use in wet and splash zones or where easy cleaning is a priority.
June 16, 2005
The actuators have a smooth profile with no angles or edges. Their surface-coated aluminum housing resists cleaning agents and caustic wash downs and meets corrosion-resistance class CRC3. Piston diameters range from 32 to 100 mm, and stroke lengths from 10 to 500 mm. Standard features include food-industry-suitable lubricating grease and selection of several stainless-steel piston rod designs and mounting attachments.
Festo Corp.
395 Moreland Rd., Box 18023
Hauppauge, NY 11788
(800) 993-3786
www.festo.com/us
