Conveyors For Small Products
AquaPruf 7600 Series Center Drive conveyors target wash-down environments, such as clean rooms, where small products must transfer.
Oct. 12, 2006
The conveyor motor mounts at any location between the two spindles to accommodate different loads. The entire unit can be disassembled for cleaning, without tools, in only 30 sec. Features include a perforated cover that lets small particles fall through rather than accumulate on the motor, UHMW belt-scraper blade to remove loose product buildup, and 400 Series stainless-steel bearings filled with H1 FDA lubricant and mounted in cast stainless-steel housings.
Dorner Mfg. Corp., 975 Cottonwood Ave., Box 20, Hartland, WI 53029, dorner.com
