This speeds installation, saves money, and minimizes leak points. The valves are available in two-way and three-way, two-position; normally open and normally closed; and mixing or diverting versions. Orifice-basket technology provides rapid assembly of seven possible orifice sizes ranging from 0.6 to 3.0 mm. A unique feature is the optional metering adjustment that lets operators dial in a custom flow rate after installation. The 3825 is available in stainless steel, brass, and FDA and NSF-approved thermoplastics. All versions are nylon encapsulated with valve coils available in all standard voltages with flying leads or DIN quick connects.
Spartan Scientific, Box 9792, Boardman, OH 44513, (330) 758-8446,
