Machinedesign 1343 Timebeltdrive 0 0
Companion Spotlight: Synchronous Pulleys
April 1, 2008
Timing belt drives Self-guiding Conidrive timing belt drives feature the N10 belt-pulley system with an offset conical projection profile on the bearing
Timing belt drives
Self-guiding Conidrive timing belt drives feature the N10 belt-pulley system with an offset conical projection profile on the bearing surface to ensure positive fit without pulley flanges, even for narrow belts.
Features & benefits
  • Nondirectional 10-mm pitch belts offer same meshing in both directions of travel
  • Polyurethane, reinforced with steel tensile-cords for strength
  • 500 to 1.000-mm lengths; belt stock also available in 50-m lengths
  • Single, double, triple-row types featuring nonchordal action
  • Fairloc integral hubs create a transverse wedge that remains attached to the solid portion of the hub on one side
Stock Drive Products
(516) 328-3300
www.sdp-si.com
Circle 151
Timing pulleys
Customized timing pulleys meet specific design requirements to minimize inertia, with special machining, tolerances, and finishes.
Features & benefits
  • Aluminum, steel, stainless steel, delrin, nylon, etc.
  • All pitch types XL, L, H, XH, T2.5, T5, T10, T20, AT5, AT10, AT20, HTD3, HTD5, HTD8, HTD14, STS3, STS5, STS8, GT5, GT8, and more
  • Available in wide widths, with or without flanges or self-retracting V grooves
  • Mount via keyways or set screws; machined to accept Taper-lock and QD bushings, and keyless locking devices
Onvio LLC
(866) 685-0404
www.onviollc.com
Circle 152
Stainless-steel sprockets
Stainless steel sprockets for synchronous belt drive systems carry high horsepower ratings.
Features & benefits
  • Taper-Lock bushing system allows for easy sprocket installation and removal; resist rust, foam degreasers, and caustic washdown solutions
  • With Poly Chain GT Carbon synchronous belts, provide a low-maintenance alternative for roller chain systems
  • Don't release contaminants associated with lubricated sprockets and chains
  • PowerGrip rubber synchronous belts are available with steel, sintered steel, grey iron, and ductile iron for durability
Gates Corp.
(303) 744-1911
www.gates.com/carbon
Circle 153
Synchronous belt drives
Synchronous Plus drives combine a high-capacity belt with a flexible, dual-sprocket design with both metric and standard-tapped holes.
Features & benefits
  • 50% more horsepower capacity than standard construction high-torque drives
  • Belt dimensions from 5 to 20-mm pitch
  • Allow for use of smaller, lighter sprockets
  • Helically wound fiberglass cords, chemically treated and designed for length stability, flexibility, and tensile strength for shock loads
  • Precise tooth formation and accurate spacing for uniform transmission of power with resistance to tooth jump and shear
TB Wood's
(717) 264-7161
www.tbwoods.com
Circle 154
March 13, 2024
March 13, 2024
Smooth Sorting with SEW-EURODRIVE!
Feb. 22, 2024
Sorting systems are essential when it comes to warehouse automation, material handling, and distribution. SEW-EURODRIVE’s automated sorting solutions increase capacity, reliability...
Setting the Agricultural Industry in Motion
Feb. 22, 2024
Agricultural products go through specialized processes of harvesting, storing, conveying, cleaning, drying, sorting, and handling to ensure that seasonal products reach the processing...
