Companion Spotlight: Springs & Retainers
Jan. 1, 2008
Spring washers CloverSpring SPEC spring washers offer more deflection than Belleville and disc spring washers for use with rotary bearings. Features &
Spring washers
Features & benefits
  • Can be stacked
  • Available in stainless steel or carbon steel
  • O.D. from 0.250 to 1.07 in; I.D. from 0.125 to 0.505 in.
  • Load at H1 ranges from 6.1 to 493.3 lb
Associated Spring-Raymond, Barnes Group Inc.
(800) 345-7732
www.asraymond.com/spec
Circle 151
Wave springs
Single-turn and multi-turn wave springs feature coiled flat wire with waves added to give a spring effect and provide lower work heights with the same force as coil springs.
Features & benefits
  • Act as load bearing devices; compensate for accumulated tolerances in assemblies and provide endplay take-up
  • Exert force or preload on assemblies to the low side of tolerances, to “snug” components; also give when parts are made to high side of tolerances
  • Ideal for short deflection applications with low to medium forces
  • Offered in many waves and material thicknesses; designed for a wide range of bore and rod diameters
  • Suit narrow radial wall dimensions, light duty, and low clearance applications and ball or roller bearing applications
Rotor Clip Co. Inc.
(732) 469-7333
www.rotorclip.com
Circle 152
March 13, 2024
March 13, 2024
March 13, 2024
March 13, 2024
