Idler sprockets
Idlers effectively create accurate tension in a chain drive.
Features & benefits
Eliminate whipping action sometimes found in drives with long centers; if chain continues to run loose it will wear at an increased rate
Prevent added wear to bearings as a result of shock loading caused by loose chain
Acquire proper chain tension when shafts in use are not adjustable
Establish approximately 120° chain wrap around a small sprocket
Available in bronze bushed, bronze bearing, needle bearing with hardened teeth, ball bearing with hardened teeth, and ball bearing with non-metallic teeth
Martin Sprocket & Gear Inc.
(817) 258-3000
www.martinsprocket.com
Circle 151
Adjustable pitch sheave
MVS adjustable pitch, heavy-duty sheave is designed for use with A, B, 3- and 5-V belts.
Features & benefits
Designed for up to 40 hp at 1,750 rpm
Each turn on adjustment screw moves flange by 1/16 in.
Bores from 1⅛ to 2⅛ in., depending on model
O.D. from 5.118 to 9.055 in.
MASKA Inc.
(800) 463-8928
www.maskapulleys.com
Circle 152
Belt, chain tensioners
Zetasassi line of belt and chain tensioners improves performance in industrial automation applications by keeping constant tension in belt and chain drive systems.
Features & benefits
Transmit torque more efficiently; decrease wear
Spring-loaded Econobelt tensioners, in rotational and linear movement types, adjust tension on chain or belt
Easy to install and maintenance-free
Offer 23% increase in chain life, 7% reduction in vibrations, and 12% reduction in noise
Reduce chain slackening
Quality Transmission Components, Div. of Designatronics Inc.
(516) 437-6700
www.econobelt.com
Circle 153
