The common profile speeds up wiring, labeling and testing. In addition to the standard knife disconnect, a lever style is available that not only matches the length of the fuse block, but also the height, for a perfect profile match. The blocks incorporate a dual center channel to accommodate a toolless bridging system. A patented push-in jumper is available in 2, 3, 4, 5, 10 or 20 positions and provides for chain and skip-bridging. The wire-insertion area of the blocks is designed so that flexible conductors with or without ferrules can be connected without difficulty. Additional features include nickelplated copper-alloy metal parts to resist corrosion and the ‘Reakdyn Principle' product design to prevent screws from backing out. The plastic housings are polyamide 6.6 with a UL flammability rating of 94-V0.
Phoenix Contact,
Box 4100, Harrisburg, PA 17111,
(800) 322-3225,
