Ceramic bearings - The Boca Bearing Co.
April 17, 2009
 The LBT Mini Full Ceramic bearings can run faster than metal bearings, reduce overall weight, and operate in extremely harsh environments. The ceramic silicon-nitride balls are harder and hold surface finish longer than steel balls. Smoother surface properties result in less friction between the balls and bearing-race surfaces. Improved thermal properties result in less heat buildup at high speeds. Ceramic is lighter, noncorrosive, and has 35% less thermal expansion and 50% less thermal conductivity. The ceramic bearings also eliminate scarring and run cooler due to less microweld adhesion.
The Boca Bearing Co., 755 NW 17th Ave., #107, Delray Beach, FL 33445, (800) 322-3256, bocabearing.com
