Brushed-dc motors target industrial uses - maxon precision motors inc.
The RE50 and RE65 mechanically commutated dc motors, with output powers of 200 and 250 W, are protected on the commutation side with a sealed aluminum housing. Cable outputs are sealed with PG cable fittings, and the shaft is secured with a radial shaft seal to guarantee IP54 rating on the flange side.
With diameters of 50 and 65 mm, the motors achieve 0.9-Nm nominal torque, speeds up to 5,500 rpm, and a 90% efficiency level.
maxon precision motors inc., 101 Waldron Rd., Fall River, MA 02720, (508) 677 0520,
www.maxonmotorusa.com
