Bright-Acid Zinc-Plating Process
Sept. 13, 2007
Enthobrite CLZ-970 bright-acid zinc-plating process provides the high productivity of a water-soluble process and improves plate distribution and deposit properties at any chloride level.
This is said to substantially increase productivity and dramatically cut zinc-plating costs. The process is specially formulated for continuous, high-through put operations. It has a high-temperature tolerance that can operate as a potassium chloride, ammonium chloride, or mixed system.
Enthone Inc. a business of Cookson Electronics, (203) 934-8611, www.enthone.com
The Enthobrite CLZ-970 process is specially formulated for continuous, high-throughput operations.
