Its synthetic oil base is thickened with a calcium sulphonate complex. The grease is said to have excellent load-carrying properties and to protect bearings from wear and corrosion.
NSF certification of FMG-2 as an H1 grease is pending. The lubricant can be applied with standard lubrication equipment. The grease can be supplied in 400-gm, 50-kg, and 180-kg packages.
Klber Lubrication North America
32 Industrial Dr.
Londonderry, NH 03053
(603) 647-4104
klueber.com
