Battery Clips
Aug. 24, 2006
Low-profile battery clips for AAAA cells are designed for high-density applications and will withstand shock and vibration.
A flow-hole SMT solder tail increases joint strength. The 0.010-in.-thick nickel-plated spring steel clips come loose (part #50) or on tape and reel (part#50TR) with 500 pieces per 13.0-in . reel. The polystyrene Carrier Tape is 24-mm wide with parts mounted on a 16-mm pitch.
Keystone Electronics Corp., 31-07 20th Rd., Astoria, NY 11105, (718) 956-8900, keyelco.com
