Battery-charge controllers use solar, PoE sources - Tycon Power Systems
July 23, 2010
The SCPOE Series of dual-input/dual-output battery charge controllers are designed for backup power and remote-power applications.
The SCPOE Series of dual-input/dual-output battery charge controllers are designed for backup power and remote-power applications. SCPOE can charge lead-acid batteries from a 5-A solar-panel input and/or Power over Ethernet (PoE) input. The units feature two outputs: A 24-W PoE output uses a high-efficiency dc/dc converter to provide 12, 18, 24, or 48-Vdc PoE and the secondary wire terminal output on the back is essentially the battery voltage.
The controllers offer protection against overcharge, overdischarge, short circuit, overvoltage, and overcurrent. The units, rated for –30 to 60°C, are suitable for year-round outdoor operation in a weatherproof enclosure.
Tycon Power Systems, 693 Draper Heights Way, Draper, UT 84020, (801) 432-0003, www.tyconpower.com
© 2010 Penton Media, Inc.
March 13, 2024
March 13, 2024
March 13, 2024
March 13, 2024
