The nut's design compensates for wear while eliminating lockup issues common when traversing from worn to unworn areas. A blend of selflubricating polyacetal, used in conjunction with precision-rolled 303-stainless-steel screw material, provides low torque and smooth operation for life. The nut performs well when run dry in conjunction with Black Ice coated screws. Minimal backlash between the leadscrew and nut interface allows for precise positioning.
Haydon Switch & Instrument Inc., 1500 Meriden Rd., Waterbury, CT 06705, (203) 756-7441, hsi-inc.com
