They generate electrical signals that vary proportionately to the position of the metal target within their sensing range. The sensors detect ferrous and non-ferrous metals (i.e., steel, aluminum, copper, etc.) and can be used to assure proper distance, size and thickness for measurements. They are available with both current and voltage outputs on the same sensor. Shielded and unshielded models are available in 12, 18 and 30-mm tubular barrels with a variety of connection options.
Eaton Corp., 1000 Cherrington Parkway, Moon Township, PA 15208, (412) 893-4043
