Adhesive/Sealant-Dispensing System
Nov. 3, 2005
The RotoCoater is designed to dispense adhesive or sealant to a bore.
A small, precision air motor spins a dispersion cup, which inserts into the bore. A metered amount of material is released into the cup to evenly coat the inner surface of the bore. The dispenser cup prevents overspray and applies a uniform, controlled bead of adhesive. The RotoCoater can be used with just about any liquid material and dispenses a controlled bead to any size or shape recess.
Hernon Mfg. Inc., 121 Tech Dr., Sanford, FL 32771, (407) 321-9700, hernonmfg.com
Strategizing for sustainable success in material handling and packaging
Download our visual factory brochure to explore how, together, we can fully optimize your industrial operations for ongoing success in material handling and packaging. As your...
Fueling the Future of Commercial EV Charging Infrastructure
Miguel Gudino, an Associate Application Engineer at RS, addresses various EV charging challenges and opportunities, ranging from charging station design strategies to the advanced...
