Actuators tackle the tough jobs
Jan. 26, 2006
Roller screws have the edge on ball screws in demanding, continuous-duty tasks.
Gary Shelton
Principal Design Engineer
Exlar Corp.
Chanhassen, Minn.
Roller screws have a series of threaded, helical rollers assembled in a planetary arrangement around a threaded shaft. They convert a motor's rotary motion into linear movement of the shaft or nut.
Rollers screws have more contact points than balls screws of the same size. This extends their life and increases stiffness and load capacity.
Planetary roller screws are efficient and compact devices that convert rotary motion into linear motion. They perform the same types of tasks as do Acme or ball screws. A comparably sized roller screw can, however, carry higher loads than a ball screw, has higher efficiency than an Acme screw, and can turn significantly faster than either. This makes them an excellent choice for demanding, high-duty-cycle applications.
Roller screws' advantages stem from how the mating parts interface. The radiused flanks of the rollers deliver point contact like that of balls on a raceway. In a roller screw, however, only the contact region of the radius is part of the profile. Therefore, a much larger radius and a high number of contact points can be packed into the available space. The result is much lower stresses within the components. Comparatively, roller screws have a load capacity as much as 15 times that of similar-size ball screws. Furthermore, low-friction rolling contact between components yields high efficiencies. Because the rolling members are fixed relative to each other and never come into contact with adjacent rollers, roller screws can turn at speeds to 5,000 rpm.
Roller screws generally have ground screws that offer high precision. The units are typically grouped in tolerance classes according to DIN 69051, Part 3. The standard expresses manufacturing tolerances as lead errors per distance of linear travel. Typical tolerance classes are G1 (0.006 mm/ 300 mm), G3 (0.012 mm/300 mm), G5 (0.023 mm/300 mm), and G9 (0.200 mm/1,000 mm).
Three different nut types add to design flexibility. Standard single-nut roller screws maximize life and have backlash of about 0.01 to 0.03 mm. Split-nut or double nut configurations eliminate backlash entirely. With the split-nut design, the nut is split transversely and a precision-ground spacer inserted between the front and back halves. Double nuts, as the name suggests, use two nuts preloaded against each other on one screw. They provide the high load rating and long life of single nuts with the zero-backlash attributes of split nuts. In both zero-backlash designs, preloading is generally 5% of the dynamic load rating.
As with other leadscrews, regular grease or oil lubrication helps maximize roller screw performance. There is no standard for lubrication intervals — screw diameter, lead, and operating conditions dictate the interval.
Higher duty cycles may require oil lubrication. In such instances, use high-performance gear oil with extreme-pressure (EP) additives and ensure that the nut components are thoroughly lubricated. Lubrication rates depend on screw diameter, number of rollers, and amount of heat to be dissipated. Oil is usually sprayed on the screw shaft during operation. Horizontal mounting lends itself to immersion lubrication, but oil levels must be deep enough to fully submerge the bottom-most roller.
Contaminants such as nonlubricating fluids, metal chips, and abrasives adversely affect all leadscrews. The first level of protection is adding wipers to the front or back of the nut. Wipers capture grease within the nut and scrape particulates from the threads as the screw cycles back and forth. This configuration requires adequate lubrication to load-bearing parts of the nut assembly. The optimum sealing option is to package the roller screw within a force tube. A fully enclosed force tube keeps lubricants in and contaminants out. Force tubes can meet IP67 ratings and mount in a wide variety of arrangements.
COMPARING OPTIONS
Designers often think of ball screws first when it comes to linear motion, but they may not be the wisest choice. Here's a look at how roller screws compare in some key performance areas.
Loads and stiffness. Due to design, ball size limits the number of contact points in a ball screw. As a result, planetary roller screws have more contact points than possible on comparably sized ball screws. More contact points equate to higher load-carrying capacities (up to 779,000 lbf in Exlar units) plus better stiffness. In practical terms, this means typical roller-screw actuators need less space to meet specified load ratings.
Travel life. With higher load capacities, roller screws deliver major advantages in working life, which is usually rated in total "inches of travel" the unit delivers in service. For instance, a 1.2-in.-diameter, 0.2-in. lead roller screw under a 2,000-lb average load will give predicted service life approximately 15 times greater than for a same-size ball screw.
Speed. Ball-screw speeds are typically limited to 2,000 rpm or less due to the balls colliding with each other as the race rotates. In contrast, the rollers in a roller screw are fixed in planetary journals at the ends of the nut and, therefore, do not have this limitation. Hence, roller screws run at speeds exceeding 5,000 rpm and produce comparably higher linear travel rates.
Fluid-power comparisons. When applications involve high loads or fast cycling, roller screws are an attractive alternative to hydraulic and pneumatic actuators. They do not require complex support systems of pumps, valves, tubing, filters, and sensors. Thus, they take up less space and last a long time with virtually no maintenance. Hydraulic leaks are not a concern and the units significantly reduce noise levels. Electromechanical units using roller screws typically have much simpler controls. They also offer the flexibility of computer-programmed positioning, a definite plus for many applications.
The Comparing linear-motion technologies chart gives an overview of the basic motion technologies in terms of performance characteristics, efficiencies, and economics.
VARIED APPLICATIONS
Rollers screws can be found in many critical, demanding, and precise linear-motion machines, ranging from artificial hearts and automated medical syringes to machine-tool presses and broaching devices. Food and beverage filling; cartoning, sealing, and palletizing equipment; as well as glass and plastic-molding operations are among other significant users.
In riveting applications, for example, roller screws can increase machine service life more than tenfold over machines using ball-screw technology. The ability to withstand high shock loads lets roller-screw actuators act directly as the upset force when riveting. Ball screws, on the other hand, have low shock resistance. Roller screws can also move rapidly — several cycles per second — on a continuous basis. Attempting similar movements with ball screws usually results in quick failures. Combining riveting with electro-mechanical servo-based systems ensures consistent fastener heights and minimal scrap.
Roller screws on servocontrolled weld guns accurately exert weld-tip force and tip position, characteristics not possible with pneumatic actuators. Compared to air cylinders, roller-screw electric actuators' position and speed can be adjusted without resetting switches or changing offsets. They are also more compact and virtually noise-free. Because roller screws provide high stiffness, weld tips do not "bounce," which extends service life. And all-electric actuators are more energy efficient than pneumatics, operate for millions of weld cycles without relubrication, and require less maintenance.
Sawmill and forestry applications provide excellent opportunities for hydraulic cylinder replacement. Eliminating the need for oil keeps the environment clean. With hydraulic systems, flow and speed can vary considerably with temperature, but this is not an issue with electromechanical systems that run consistently regardless of temperature.
The efficiency of converting electric power to linear motion exceeds 90% with electric actuators, compared with about 40% for hydraulic drives. Canter, edging, and merchandising saws, as well as high-speed fences that rely on roller screws can survive rugged sawmill environments while generating fast, accurate, and high forces. The flexibility of servocontrolled, electric systems also makes cutting a variety of patterns simple and cost effective.
Comparing Linear-Motion Technologies
Roller screws
Acme screws
Ball screws
Hydraulic cylinders
Pneumatic cylinders
Load ratings
High
Moderate
Moderate
High
Moderate
Lifetime
Long, many times greater than that of ball screws
Short, due to high friction and wear
Moderate
Can be long with proper maintenance
Speed
Fast
Slow
Moderate
Moderate
Fast
Acceleration
High
Low
Moderate
High
High
Electronic positioning
Easy
Moderate
Easy
Difficult
Very difficult
Stiffness
High
High
Moderate
High
Low
Shock loads
High
High
Moderate
High
High
Relative space requirements
Minimum
Moderate
Moderate
High
High
Friction
Low
High
Low
High
Moderate
Efficiency
>90%
≈40%
>90%
<50%
<50%
Installation
Compatible with standard servoelectronic controls
User may have to engineer a motion/actuator interface
Complex, requires servovalves, high-pressure plumbing, filters, pumps, linear positioning, and sensing
Very complex, requires servovalves, plumbing, filters, compressors, linear positioning, and sensing
Maintenance
Low
High, due to poor wear characteristics
Moderate
High
High
Environmental impact
Minimal
Minimal
Minimal
Hydraulic-fluid leaks and disposal
High noise level
MAKE CONTACT
Exlar Corp.,
(952) 368-3434, exlar.com
Roller-screw guidelines
Here's an overview of some key design considerations when selecting and sizing roller screws.
Life. Expected life of a roller screw is defined as the linear travel distance that 90% of the screws are expected to meet or exceed before experiencing metal fatigue. For a single, nonpreloaded nut:
L10 = (C/F ) 3 S
where L10 = travel life in millions of mm; C = dynamic load rating, N; F = cubic mean applied load, N; and S = lead, mm.
Critical speed. Critical speed depends on screw length and the type of bearing supporting the screw. The rotational speed of a roller screw should always be less than the critical speed, determined by the following relationship.
where nc= critical rotational speed under zero axial load, rpm; do = screw diameter, mm; fs= support bearing factor (from accompanying figures); and l = screw length, mm.
Compressive axial loads reduce critical speeds while tensile loading increases them.
Mechanical speed limit. Screw length and mounting configuration are not the only parameters that affect roller-screw speed. The nuts have mechanical speed limits that applications must not exceed. Maximum speed depends on screw diameter and lubrication. Maximum mechanical speed in rpm for a single, nonpreloaded nut is:
Oil lubrication = 140,000/d0,
Grease lubrication = 90,000/do,
where d0 = screw diameter, mm.
Buckling force. Excessive compressive loads can buckle roller screws. Like critical speeds, buckling force is a function of screw length, diameter, and type of bearing supporting the screw. When sizing roller screws, the maximum applied compressive load must be less than the buckling force Fb, determined by:
where fb= buckling force bearing factor (from accompanying graphic); do= screw diameter, mm; and l = screw length, mm.
Torque. Engineers should size the roller screw's torque to match the motor. These numbers are then compared against the torque rating of the motor/drive controlling the roller-screw velocity and position. Both load torque and acceleration torque must be less than the motor's torque rating.
Calculate torque under load from:
λ = SF/(2π η)
where λ = torque, Nm; F = applied load, N; S = screw lead, m; and = motor efficiency, %.
Torque under acceleration is calculated from:
λ = (Il + Im)α
where λ = torque, Nm; Im = inertia of the proposed motor's armature (from motor specifications), N-m-sec 2 ; and = motor acceleration, rad/sec 2 .
Il = reflected inertia due to load, N-m-sec 2 , is determined from:
where S = screw lead, m; m = mass of the applied load, N; and g = gravitational constant, 9.75 m/sec 2 .
Linear speed. Linear speed of the follower (nut) is a function of the shaft's rotational speed and the roller-screw lead. Calculate linear speed of the follower from:
V = nS
where V = linear velocity, mm/sec; n = follower rotational speed, rev/sec; and S = screw lead, mm.
